This latest addition to our PC Card line-up operates on our broadband network with typical download speeds of 450-800 kbps and uploads speeds of 300-400 kbps. With the PC5750 and
VZAccess Manager, you can connect to corporate applications, email, instant messaging and the Internet. This PC Card also comes with a high performance hinged antenna and an external antenna connector to boost signal strength and improve network connectivity in fringe areas.
Windows Vista™ capable.
Features- BroadbandAccess and NationalAccess high-speed wireless data access
- Rev. A Capable
- VZAccess Manager software for easy connection management
- Easy to install and use
- High performance, hinged antenna for increased speed and coverage
- Intuitive user interface
- 32-bit CardBus interface(3.3V) for lower power consumption
- External Antenna Connector (External antenna sold separately)
System Requirements- Microsoft® Windows® 2000, XP and Vista™
- Mac OS X 10.3.9 or higher
- Standard Type II PCMCIA card slot (Cardbus) -CD-Rom drive
- 32 MB memory
- 14 MB free hard disk space
Specifications- Dimensions: Size: 4.6" (H) x 2.1" (W) x 0.2" (D)
- Weight: 1.8 oz
