The smaller and lighter V640 ExpressCard operates on the Verizon Wireless broadband network and is capable of speed bursts of up to 2.0Mbps. With VZ
Access Manager you can increase your productivity by easily managing your remote access connections and business applications. The V640 ExpressCard features a multi-color LED service status indicator for data throughput monitoring and a flip-up antenna to enhance RF performance while on the go.
Basic Information
Size: 4.4H x 1.3W x 0.19D inches
Weight: 1.4 oz
Basic Features
- All Digital - 1xEVDO, 1xRTT, IS 95 (800/1900 MHz)
- Express Card Technology
- Supports USB 2.0 and PCI Express applications
- High Speed Data Transfer (up to 2.0 Mbps)*
- 2-way SMS Messaging
- Flip-up Antenna
- LED Service Status Indicator
- VPN Compatible
- External Antenna Connector
- VZAccess Manager software for easy connection and management
- Supports Mac OS X 10.4.7 or higher
- Meets FCC SAR limit. Manufacturer's highest FCC reported SAR 1.14 on body. Actual SAR may vary.
*Typical upload speeds of 60-80 Kbps. Actual speeds and coverage may vary.
