The KPC650 card utilizes our VZ
Access manager which serves as a focal point for all of your internet connection needs. Using Broadband
Access the KPC650 operates with typical download speeds of 400-700 kbps and bursts up to 2.0 Mbps. It also features an adjustable antenna which can be angled for optimized reception.
Basic Information
Size: 2.13H x 4.84W x 0.51D inches
Weight: 2.01 oz
Basic Features
- BroadbandAccess high-speed wireless data access of up to 2.0 Mbps
- VZAccess Manager software for easy connection management
- Hinged Antenna
- BroadbandAccess and NationalAccess compatible
- Dual-band receive diversity for better network performance
- SMS capable
- 32-bit CardBus interface(3.3V) for lower power consumption
- LED indicator for service availability and data transfer status
- Quick2Net compatible
- Meets FCC SAR limit. Manufacturer's highest FCC reported SAR: 1.17. Actual SAR may vary.
