The compact and lightweight
KPC680 ExpressCard is
Rev. A capable.* Operating on our high speed wireless broadband network the
KPC680 provides the mobile professional access to critical information – fast. And with
VZAccess Manager you can increase your productivity by easily managing your remote access connections and business applications. The
KPC680 ExpressCard also features a dual–color LED service status indicator for data throughput monitoring and a detachable, corkscrew flip–up antenna and dual external antenna ports to enhance RF performance while on the go.
* Typical download speeds average 600–1400 kbps based on our network tests with 5 MB FTP data files, without compression. Typical upload speeds average 500–800 kbps. Actual speeds and coverage may vary. If usage exceeds 5 GB/line/month, we reserve the right to reduce throughput speeds to a maximum of approximately 200 Kbps.
