Old 08-01-2008, 10:14 PM   #1 (permalink)
Default How to enable / disable GPS location on Boulder
Enabling / disabling GPS location - Verizon Wireless G'zOne Boulder
  1. From the main screen, press the center of the 5-way navigation pad to choose Menu.
  2. Select Settings & Tools.
  3. Select Phone Settings then press the center of the 5-way navigation pad to choose OK.
  4. Select Location, then press the center of the 5-way navigation pad to choose OK.
  5. Enter Code (the default code is the last 4 numbers of the mobile phone number) then press the center of the 5-way navigation pad to choose OK.
  6. Select the desired setting then press the center of the 5-way navigation pad to choose OK. Location On Location Based Services enabled 911 Only GPS enabled only when 911 is dialed
How to enable / disable GPS location on Samsung Renown admin_mvu Samsung Renown 0 11-22-2008 01:01 PM
How to enable / disable GPS Location on Nokia 6205 admin_mvu Nokia 6205 0 08-09-2008 04:57 PM
How to enable / disable GPS location on Motorola V750 admin_mvu Motorola V750 0 08-01-2008 10:32 PM
How to enable / disable GPS location on LG Dare admin_mvu LG Dare 0 06-26-2008 03:57 PM
How to enable / disable GPS location on LG enV2 admin_mvu LG enV2 0 06-05-2008 12:28 PM
