Go Back   My Verizon Users > The Basics > Tips & Tricks
Tips & Tricks Share general tips and tricks of using Verizon service or products here. Specific tips on particular phones will be in the Verizon Phones section.
Old 03-08-2007, 02:06 PM   4 links from elsewhere to this Post. Click to view. #1 (permalink)
Default How to enable EVDO DUN on ANY EVDO capable phone in 10 easy steps!
Step 1
http://www.myvusers.com/forums/userg...pst2.7b215.zip
or
Go to the following link. The very first post should be a link to QPST 2.7 build 215. You will have to register in order to download it.
http://www.mobile-files.com/forum/s...&highlight=QPST
Step 2
Download QPST 2.7 build 215 and install it.
Step 3
Connect your phone to your PC via usb cable or via bluetooth.
Step 4
Launch the QPST Configuration Tool
Add the port your phone is listening on. If your phone is capable, you can connect via bluetooth or simply use a USB cable, the choice is yours.
Be sure to specify the correct port.
If you are not sure what port your phone is connected to, try downloading BitPim and using the auto-detect feature to determine which port your phone is listening on.
You'll know that you've specified the correct port once the Configuration Tool has picked up your phone.
Step 5
Launch the Service Programming tool that is part of the QPST Suite.
Step 6
Connect to your phone with the Service Programmer. If you have completed the previous steps successfully, you will see your phone listed.
Step 7
Click the 'Phone' menu, then 'Read from Phone'. Wait for the Service Programmer to read the data from your phone. BEFORE making any changes, click 'Save to File' and BACKUP your qcn file. DO NOT SKIP THIS STEP!
Step 8
Once you have backed up your qcn file. Scroll to the 'M .IP' tab. Once there, select your entry from the list, and click 'Edit'.
Step 9
You must edit your 'Tethered NAI' so that your phone will use the same login information for both EVDO and CDMA-1X network access. If your mobile number is 1234567890 then your 'Tethered NAI' will read '1234567890@dun.vzw3g.com'. Change it so that it reads '1234567890@vzw3g.com'. Once complete, your 'NAI' and 'Tethered NAI' should be EXACTLY the same. Click 'OK'.
Step 10
Click 'Write to Phone' to write the modified qcn file to your phone.
Enjoy, your 'DUN'!
To use the EVDO DUN service, add an new dialup connect with the following credentials:
Phone Number: #777
Username: MobileNumber@vzw3g.com (ex: 1234567890@vzw3g.com)
Password: verizon
Be sure to select your phone as the default modem for this connection.
Cheers,
randyman
Old 03-09-2007, 12:30 PM   #2 (permalink)
DUN = Dial Up Networking.
This means, if you have a laptop, connected to your EVDO enabled phone, you can use it as your wireless modem so you can browse internet at EV-DO speed ~ several hundred Kbps.
Using your minutes, of course, but without having to sign up for a separate data service plan at additional fee.
I haven't tried this myself. Let me know if anybody has success with it.
Old 12-04-2007, 01:08 PM   #3 (permalink)
nemesis91101 is on a distinguished road
i have tried it but i edited that info without qpst just using the phones service menu. I dont know if i am getting charged so i will let you guys know come january
nemesis91101 is offline   Reply With Quote
Old 12-04-2007, 06:51 PM   #4 (permalink)
Walkie Talkie User
buzzdar's Avatar
buzzdar will become famous soon enough
That is just awesome. I Finially got it to work. I can now teather my Voyager. Will Work Great on my Laptop when im on the go.
[URL="http://mywirelessusers.com"]MyWirelessUsers.com[/URL] to sign up for verizon wireless Great Deals.
buzzdar is offline   Reply With Quote
Old 12-04-2007, 09:46 PM   #5 (permalink)
It's good to know that it even works on Voyager.
Old 12-05-2007, 12:41 PM   #6 (permalink)
Walkie Talkie User
buzzdar's Avatar
I can now do so much more on my voyager than i ever thought i ever could. I can now connect to my laptop for internet. I can stream Music and stream videos over the internet all to my VOYAGER Phone. Best Money i ever spent. I was do for an upgrade so i got an additional 100.00 off the price of the voyager making it 199.99 and in turn selling my Samsung U740 for 199.99 basically costing me next to nothing to upgrade my phone to a much better one.
Old 12-06-2007, 12:10 AM   #7 (permalink)
I guess it's time to update your avatar now.
Old 01-03-2008, 01:42 PM   #8 (permalink)
Compnird is on a distinguished road
Default Can't use when out of town.
Awesome! I've been using standard #777 DUN with my U740 and now seem to have a little bit faster connection.
FYI, it shows up on your bill as minutes used, not data usage. The number shows as (777) 000-0000 on your bill.
I do have a problem though. I somehow wasn't able to connect while outside my home area (Seattle). I was in Minneapolis and tried connecting but got an 'Invalid Username' message. Then again in Louisville, same message. Connected fine when I got home to Seattle.
Anyone know why this might happen? I had to pay for airport wifi which I HATE doing. :|
Compnird is offline   Reply With Quote
Old 01-03-2008, 03:18 PM   #9 (permalink)
I wonder if EVDO was available in those two cities. I would hope so but EVDO is not completely nationwide yet.
Old 01-03-2008, 05:21 PM   #10 (permalink)
Quote:
I am pretty sure they have EvDO. I saw full signal strength on both the 1X and EV lines. I thought maybe it just doesn't like to roam or something.
I will try it again next time I am out of town and see if I can't troubleshoot it more. I was just hoping someone had at least seen the same thing and could give me some insight.
LinkBacks (?)
LinkBack to this Thread: http://www.myvusers.com/forums/tips-tricks/823-how-enable-evdo-dun-any-evdo-capable-phone-10-easy-steps.html
Posted By For Type Date
N810 Phone Connection - Internet Tablet Talk Forums This thread Refback 11-21-2008 04:52 PM
Help with: TomTom to use Verizon Wireless for Data in After-sale GPS inquiries forum - GPS POI Data This thread Refback 11-13-2008 06:20 AM
7 posts tagged ?eee? - karen?s Blog on Vox This thread Refback 09-24-2008 04:40 PM
EeeUser ASUS Eee PC Forum / Successful bluetooth phone connection This thread Refback 09-24-2008 11:34 AM
Cant get a working verizon wireless voyager phone buzzdar Official Verizon Rant Thread 1 06-11-2008 11:41 AM
Using PC with V CAST Music FAQ admin_mvu VCAST 2 01-02-2008 11:20 PM
Using V CAST Music Phone FAQ admin_mvu VCAST 1 01-02-2008 11:15 PM
Google Phone is in the works, say insiders admin_mvu Cellular News & Announcements 0 03-19-2007 09:48 AM
Verizon Denies Giving NSA Phone Records admin_mvu Verizon Wireless News & Announcements 0 05-17-2006 01:22 PM
