Go Back   My Verizon Users > The Basics > Tips & Tricks
Tips & Tricks Share general tips and tricks of using Verizon service or products here. Specific tips on particular phones will be in the Verizon Phones section.
Old 12-21-2007, 05:49 PM   #1 (permalink)
Default How to install VZAccess Manager for Mobile Office Kits
Installing VZAccess Manager for Mobile Office Kits
  1. Insert Disc 2 Verizon Wireless Installation into CDROM drive (CD will auto-start). Click Install VZAccess Manager.
    If set up does not automatically start, click the Start button on the taskbar and choose Run. Type D:\Start (where D is the letter of your CD-ROM drive) and click OK.
  2. Click Next.
  3. To continue the installation, select I agree... then click Next.
  4. Click Next.
  5. Click Next.
  6. Click Finish.
  7. Click Next.
  8. Select the appropriate option and click Next.
    If you do not want to use VZAccess Manager to control your Wi-Fi connection, select Detect WWAN device only (1xEVDO/1xRTT/CDMA) and skip to step 11.
  9. Click Next.
  10. Click Next.
  11. Click Next.
  12. Select the appropriate option (Serial port, USB port or PC Card) then click Next.
  13. Click Next.
    The phone model will vary depending on the phone being used.
  14. Enter the 10 digit mobile number of the phone to be used and click Next.
  15. Click Test Device.
  16. Click OK.
  17. Click Next.
  18. Click Finish.
  19. The Venturi Client installation will begin. Click Next.
  20. Click Next.
  21. To continue the installation, click Yes.
  22. Click Next.
  23. Click Finish. The computer will restart to complete the installation.
VZAccess Manager Problems aznhypnotix BroadbandAccess 1 09-23-2008 10:17 PM
VZAccess Manager Error Codes Duff Ask the Tech? 2 07-30-2008 04:58 PM
How to establish / terminate an internet connection using VZAccess Manager admin_mvu BroadbandAccess 0 01-03-2008 07:06 PM
How to enable / disable prompt for user name and password on VZAccess Manager admin_mvu BroadbandAccess 0 01-03-2008 06:35 PM
How to install Mobile Office Kit admin_mvu Tips & Tricks 0 12-21-2007 05:48 PM
