Go Back   My Verizon Users > The Basics > Tips & Tricks
Tips & Tricks Share general tips and tricks of using Verizon service or products here. Specific tips on particular phones will be in the Verizon Phones section.
Old 12-21-2007, 04:24 PM   #1 (permalink)
Default How do I send a TXT message?
For most digital phones:
To Send:
  • Select Messages
  • Select Send To or Send New
  • Enter email address or mobile number
  • Select Next
  • Enter your message, select Next
  • Select Options, and select Send
Helpful Text Entry Tips:
When entering text, make sure you use the "alpha" (ABC or TAP) entry mode and not the "T9", "iTAP" or "WORD" entry mode. The "@" can be found under "sym" or "symbols". When entering numbers, make sure you use the "123" or "NUM" entry mode.
How to create and send a PIX message on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 09:08 PM
How to create and send a TXT message on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 09:07 PM
How to create and send a PIX message on Motorola V750 admin_mvu Motorola V750 0 08-01-2008 10:30 PM
How to create and send a TXT message on Motorola V750 admin_mvu Motorola V750 0 08-01-2008 10:26 PM
How to create and send a TXT message on LG Chocolate 3 admin_mvu LG Chocolate 3 0 07-16-2008 12:54 PM
