Go Back   My Verizon Users > The Basics > Tips & Tricks
Tips & Tricks Share general tips and tricks of using Verizon service or products here. Specific tips on particular phones will be in the Verizon Phones section.
Old 08-10-2006, 08:03 PM   #1 (permalink)
Cordless Phone User
ClwTL will become famous soon enough
Smile Make your own ringtones
To get this to work you need four things.
1. A motorola V710 or e815. Sorry guys, these are the only two.
2. A transflash memory card (any size will do)
3. A memory card reader or adapter to be placed in your computer
4. Internet connection
Thats it. There is a glitch that allows you to make your own ringtones without performing seems edits (seem edits void warranty). Essentially you have to put music (or whatever you want as a ring tone) on your memory card and place the card in your phone. Where you get the music is up to you but I have found that online sites that sell cds are the best because they give you 30 second clips of the songs as a free preview to decide if you want to buy the album. 30 seconds is coincidently the max length of an audio clip that can be sent in a pix message. All you do is save the preview clip to your desktop and then copy it into the memory card. The music works best in mp3 format but most online sites like walmart.com and bestbuy.com use that file type anyway.
Now here is the incredibly sly, sneaky, and down right crafty way to do this...
Send a pix message to a fake number (example- 555-555-5555). In this message, select INSERT -> Sound and then "switch storage device" to the memory card and pick the audio file you want as your ring tone. Send the message. After attempting to send the message it will tell you that it failed delivery (this is good). Go back into your sent message folder and open the failed message. The audio you want as a ringtone will play automatically. Go to menu then save. Select the audio file and use the soft key corresponding to "store". It will give you two options as to where to save, select "phone" It will then say "store only" or "apply as ringtone", select apply as ringtone and there you go. Free ringtone.
Why it works: Moto has a block in the phone for music transfer from card to phone for use as a ringtone. By sending it to a bogus destination, the resulting failed message receipt is saved, with audio, to the phone itself. Now that the audio is on the phone you can, due to bypassing the block, set it as a ringtone. The best part of this is that since the pix message didn't go through, you didn't get charged a quarter for it (even if you don't have a pix plan) so it is literally free to do it as many times as you want. Better than 2.99 a song through VZ Tones Deluxe, dontcha think?
[I][B]asf[/B][/I]
[IMG]http://images.sci-tech-today.com/images/id/8135/samsung-verizon-multimedia-digitial_cameras_sci.jpg[/IMG]
[B]Phones: [/B][COLOR="Blue"]Samsung a990 (stock so far)[/COLOR] [COLOR="Red"]Moto V3m (unlocked)[/COLOR] [COLOR="SeaGreen"]Moto e815 (unlocked + seem edits)[/COLOR] Moto v710 ("Super Dave" software)
ClwTL is offline   Reply With Quote
Old 08-11-2006, 09:53 AM   #2 (permalink)
Wow... we are starting to get pretty fancy - thanks for the great tip.
Old 08-11-2006, 09:59 AM   #3 (permalink)
Cordless Phone User
cdma's Avatar
cdma is on a distinguished road
That is a great tip. Who would've thought of that? Too bad I don't have the Motorola phones but it should help out other Motorola phone owners.
cdma is offline   Reply With Quote
Old 08-14-2006, 07:29 PM   #4 (permalink)
Cordless Phone User
Quote:
i'll have a tip or two for your phone soon too.
[I][B]asf[/B][/I]
Chocolate 3 and Bitpim (do ringtones work?) OregonTrail LG Chocolate 3 3 09-03-2008 09:09 PM
Make your own ringtones (All Vcast capable Samsungs or Motorolas) ClwTL Tips & Tricks 64 08-21-2008 06:54 PM
23 cool ringtones for only $9.99 admin_mvu Free Ringtones for your phone 3 02-26-2008 02:11 PM
How to make your own MP3 ringtones for Samsung a950 admin_mvu Samsung a950 1 01-08-2008 07:04 PM
A990 Peeps, make your own Ringtones ClwTL Samsung a990 4 11-08-2007 09:04 AM
