Checking minutes used
If your phone supports browser, as most of the Verizon phones do, you can check how many minutes used and how many text message you have sent/received for free from your phone.
1. Start your browser (usually by one of the 4-way keys)
2. Scroll down to (1) Select My Account
3. Select (2) Usage
4. Enter your billing zip code. Click OK.
5. Select Minutes (or TXT Messages)
It will tell you how many minutes you have used during Peak, Off Peak, Weekend, Peak IN, Off Peak IN
From #3, you have 7 different options you can choose to see your balance, payment information, your plans, etc.
These are all Air time FREE so check as often as you like, if you think you might be over your monthly limit.
