01-03-2008, 06:51 PM
#1 (permalink)
How to enable / disable auto save message feature on Samsung Gleam (SCH-u700)
Enabling / disabling the Auto Save messaging feature - Verizon Wireless Gleam (SCH-u700)- From the main screen, press the left soft key to choose Message.
- Press the left soft key to choose Settings.
- Select Auto Save Sent then press OK.
- Select the desired setting then press OK.
- Select On to enable the auto save feature.
- Select Off to disable the auto save feature.
- Select Prompt to have the handset ask to save the message.
