Go Back   My Verizon Users > Verizon Phones > Samsung Phones > Samsung Alias
Samsung Alias Discuss Samsung u740 Alias Here.
Old 12-21-2007, 05:35 PM   #1 (permalink)
Default How to format a memory card on Samsung u740
Formatting a memory card - Samsung SCH-u740
This procedure will erase all data on your card. It is recommended that you have a recent backup of your data; unless you are willing to lose it.
  1. From the main screen, press OK to choose Menu.
  2. Select Settings & Tools then press OK.
  3. Select Memory then press OK.
  4. Select Card Memory then press OK.
  5. Press the right soft key to choose Options.
  6. Select Format Card then press OK.
  7. When prompted, select Yes then press OK to confirm you want to format the card.
Old 08-07-2008, 06:49 PM   #2 (permalink)
shellebrity is on a distinguished road
here's my problem:
i try to format the card, and it says "format failed."
i also can't connect my phone with the cord i received in my "music essentials kit," because the port doesn't match.
help?
shellebrity is offline   Reply With Quote
Old 08-07-2008, 09:37 PM   #3 (permalink)
You might want to try a different card. Maybe the card is bad.
What error message are you getting? What ports are not matching? USB?
How to format a memory card on Samsung Renown admin_mvu Samsung Renown 0 11-22-2008 08:45 PM
How to insert / remove a memory card on Samsung Renown admin_mvu Samsung Renown 0 11-22-2008 02:54 PM
How to insert / remove a memory card on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:58 PM
How to format a memory card on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:58 PM
How to format a memory card on Samsung Glyde admin_mvu Samsung Glyde 0 05-23-2008 05:34 PM
