Go Back   My Verizon Users > Verizon Phones > Smartphones > Discontinued Smartphones > Palm Treo 755P
Palm Treo 755P Discuss Palm Treo 755P Here
Old 12-28-2007, 05:33 PM   #1 (permalink)
Default How to perform a hard reset on Palm Treo 755P
Performing a hard reset - Palm Treo 755p
A hard reset is the last resort for troubleshooting. This reset will erase all data and restore preferences to factory default specifications. Performing a hard reset is only recommended when the existing data has been backed up or is unwanted.
If third party software has been installed recently, refer to Palm Support Knowledge Library Article 27908 for assistance diagnosing problems caused by third party applications.
  1. Disconnect the AC charger and USB sync cable.
  2. Press the battery door release button then slide the battery door downward to remove.
  3. Remove the battery.
  4. Press and hold the Power / End key while re-inserting the battery.
  5. When presented with the Powered by Access logo, release the Power / End key .
  6. Press Up on the 5-way navigation pad.
  7. Select the desired language, then press the center of the 5-way navigation pad.
  8. Press the center of the 5-way navigation pad to choose Yes.
How to perform a hard reset on Samsung Omnia admin_mvu Samsung Omnia 0 12-20-2008 11:12 PM
How to perform a hard reset on Palm Centro admin_mvu Palm Centro 0 06-17-2008 03:58 PM
How to perform a hard reset on Motorola Q9m admin_mvu Motorola Q9m 0 05-23-2008 06:03 PM
How to perform a soft reset on Palm Treo 755P admin_mvu Palm Treo 755P 0 12-28-2007 05:32 PM
How to do a hard or soft reset on Palm Treo 700wx admin_mvu Palm Treo 700wx 0 03-12-2007 05:03 PM
