Go Back   My Verizon Users > Verizon Phones > Smartphones > Discontinued Smartphones > Palm Treo 755P
Palm Treo 755P Discuss Palm Treo 755P Here
Old 12-28-2007, 05:32 PM   #1 (permalink)
Default How to perform a soft reset on Palm Treo 755P
Performing a soft reset - Palm Treo 755p
A soft reset is the most useful tool for resolving a variety of issues. In most cases, a soft reset will not effect the data on the device, unless the battery is very low. It is a good practice to perform a sync operation before any reset to ensure that your data is backed up.
  1. Disconnect the AC charger and USB sync cable.
  2. Press and hold the Power / end key to turn the wireless radio off.
  3. Press the battery door release button then slide the battery door downward to remove.
  4. Remove the battery.
  5. Re-insert the battery and replace cover.
  6. Ensure desired Automaticaly set option is selected then tap Done.
    • Nothing
    • Date and time
    • Date, time and time zone
  7. Press and hold the Power / end key to turn the wireless radio on.
How to perform a soft reset on Samsung Saga admin_mvu Samsung Saga 0 11-16-2008 08:47 PM
How to perform a soft reset on Palm Centro admin_mvu Palm Centro 0 06-17-2008 03:57 PM
How to perform a hard reset on Palm Treo 755P admin_mvu Palm Treo 755P 0 12-28-2007 05:33 PM
How to perform a soft reset on Samsung i760 admin_mvu Samsung i760 0 12-21-2007 05:24 PM
How to do a hard or soft reset on Palm Treo 700wx admin_mvu Palm Treo 700wx 0 03-12-2007 05:03 PM
