06-17-2008, 03:56 PM
#1 (permalink)
How to enable / disable auto save messaging on Nokia 6205
Enabling / disabling the Auto Save messaging feature - Nokia 6205
- From the main screen, press the left soft key to choose Message.
- Press the left soft key to choose Settings.
- Select Auto Save Sent then press OK.
- Select the desired setting then press OK. On Auto Save is enabled. Off Auto Save is disabled. Prompt The handset will ask to save each time a message is sent.
