Discontinued Phones Discuss discontinued Audiovox, Pantech, UTStarcom phones Here
Old 02-04-2008, 08:58 PM   #1 (permalink)
claudiab is on a distinguished road
Unhappy help with CDM 8945
I have a CDM 8945 phone. I bought the verizon music essentials kit to download music on my pc. i loaded the disk and connected the usb cable. on the phone it said i was connected. but on the pc it said there was nothing connected to pc. I also have i Venus and i can download music on it fine. anybody have the same problem? should i uninstall and try to install again? any suggestions...
claudiab is offline   Reply With Quote
Old 02-04-2008, 10:31 PM   #2 (permalink)
Have you tried installing the driver for CDM 8945? The PC has to recognize the phone as CDM8945 before you can communicate with it.
Old 02-05-2008, 07:18 AM   #3 (permalink)
i dowloaded the cd that it came with it and it downloads the software for drivers. When i did the venus software it worked fine.
Old 02-05-2008, 05:28 PM   #4 (permalink)
got it working. thanks
Old 02-06-2008, 09:00 AM   #5 (permalink)
What did you do?
Old 02-06-2008, 09:27 PM   #6 (permalink)
i downloaded the software from the verizon site. and that worked. I dont know if it was different from the CD that i bought with the kit. but htat did it. I havent tried to download my husbands venus with this software. I hope it works for the venus too.
