Go Back   My Verizon Users > The Basics > Ask the Tech?
Ask the Tech? Here you can ask specific questions to Technical Staff working at Verizon Wireless. They can answer specific questions that are not confidential. Ask away!
Old 02-18-2008, 04:32 PM   #1 (permalink)
Telegraph User
newtoverizon_sb's Avatar
newtoverizon_sb is on a distinguished road
Send a message via Yahoo to newtoverizon_sb
Question Contacts copier (from Samsung)
I currently have an A920 Samsung with Sprint and will be changing over to Verizon within a couple of weeks...is it possible to use the Contacts copier software to copy my contacts onto a new phone.....say if it were anything other than Samsung?
Not that I have all entries used up, BUT it would be fantastic not to have to enter each and every one of them again...I will if I have to though. Just wondering if it would be possible...would make life that much more liveable, lol.
Thanks in advance for your responses.
sb
newtoverizon_sb is offline   Reply With Quote
Old 02-18-2008, 04:53 PM   #2 (permalink)
What is Contacts Copier? Is this something Samsung provide for all Samsung phones?
I haven't heard of anything that can copy contacts between two different operators.
You might want to contact Samsung if they provide something that can copy contacts from one Samsung phone to another Samsung phone, if you are getting another Samsung.
Once you have Verizon phone, you'll never have to enter contacts manually again when you update your phone. Either the store can do that for you. Or, you can sign up for free contacts backup (over the air, done for free).
Old 02-18-2008, 05:40 PM   #3 (permalink)
Telegraph User
Thumbs up
Thanks so much, that's the answer I thought I would get.
btw it is a downloadable software, I'm presuming by Samsung, I don't have the link anymore...pretty sure it's at their website tho, it is copyright to them...I don't like to download anything that looks/sounds fishy. It's basically a backup program for your contacts. To put a (nother useless) file (I might add, lol) on your computer.
_____________________
(Update, while I was typing this I decided I should search for the link...it IS from Samsung (samsung.com) and it's called Samsung Contacts Copier version 1.1.0.0 for my model type sph-a920) I'm NOT sure if it's available for other Samsung models, I would hope so. I found out about it in my user manual.
I didn't want to make any unnecessary posts.
Thanks again.
How to assign In Case of Emergency (ICE) contacts on Samsung Renown admin_mvu Samsung Renown 0 11-22-2008 08:53 PM
How to send contacts via Bluetooth on Samsung Renown admin_mvu Samsung Renown 0 11-22-2008 02:45 PM
How to send contacts via Bluetooth on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 09:01 PM
How to send contacts via Bluetooth on Samsung Glyde admin_mvu Samsung Glyde 0 05-23-2008 05:52 PM
Back up your contacts for free admin_mvu Tips & Tricks 6 01-09-2008 11:01 AM
