Go Back   My Verizon Users > The Basics > Ask the Tech?
Ask the Tech? Here you can ask specific questions to Technical Staff working at Verizon Wireless. They can answer specific questions that are not confidential. Ask away!
Old 02-02-2008, 09:08 AM   #1 (permalink)
Duff is on a distinguished road
Default VZAccess Manager Error Codes
Hello,
Can someone tell me where I can find a listing of the VZAccess Manager error codes? For the several weeks I have had nothing but problems connecting or staying connected to BBA. I have not installed any new hardware or software. Had been working fine for the past couple months. I have made several calls to Verizon with mixed results. I am finding error codes in the VZAccess Manager log, but there is no information about what the error codes mean. If the problem is on my end I need to know that so I can attempt a fix or at least pinpoint where the problem originates. (i.e. Modem, hardware conflict, software conflict, etc)
Specs
VZAccess Manager: 6.6.2
Modem: USB720
Issues on: Desktop AND Laptop (not networked together)
Thanks in advance,
Duff
Duff is offline   Reply With Quote
Old 02-12-2008, 09:22 AM   #2 (permalink)
TJH221 is on a distinguished road
Default same problem for about two weeks
Duff - I'm having the same problem with my Verizon network card aqnd I was wondering if anybody has gotten back to you. When I called Verizon, the number displayed in the error message, The tech kept insisting that I remove my network card and plug in my ethernet cable so he could remote into my laptop. I kept trying to tell him that I do not have a wireless modem but a network card. He kept insisting that I needed a modem to access and when I told him that I have gotten on to the network before and this problem just started a week ago, he said it was impossible. He then told me to go to a Verizon store and they will help me. When I did, they said they couldn't help me in the store and I would have to call the helpdesk - they gave me the same number I called. So it's been three weeks and I'm paying $80 a month for a network card I can't use. So don't feel bad, you're not alone.
TJH
TJH221 is offline   Reply With Quote
Old 07-30-2008, 04:58 PM   #3 (permalink)
Telegraph User
aznhypnotix is on a distinguished road
Send a message via AIM to aznhypnotix
try a google search for duns error.
here are some common errors for vz access manager, error qa 913, ras error 691, error qa 920, username/password error
aznhypnotix is offline   Reply With Quote
VZAccess Manager Problems aznhypnotix BroadbandAccess 1 09-23-2008 10:17 PM
How to enable / disable system tray popup status window on VZAccess Manager admin_mvu BroadbandAccess 0 01-03-2008 07:10 PM
How to establish / terminate an internet connection using VZAccess Manager admin_mvu BroadbandAccess 0 01-03-2008 07:06 PM
How to enable / disable prompt for user name and password on VZAccess Manager admin_mvu BroadbandAccess 0 01-03-2008 06:35 PM
How to install VZAccess Manager for Mobile Office Kits admin_mvu Tips & Tricks 0 12-21-2007 05:49 PM
